Not your typical paper question...I want scorch!
I’m working on a project for an artist where he is looking for an image etched into paper.
HOWEVER.
He wants slight scorching…not crispy…but definitely evidence of scorch…
Currently working with 1000 speed, 15 power and 225 dpi.
Any suggestions would be immensely helpful because as always, tight deadline! His show opens next friday and he wants 30 prints. Each takes about 2 hours with the current settings.
What type of paper?
Cheat. Stack the paper on top of mdf or some other wood. You’ll get much more smoke that way.
Oh, wait. You’re engraving… That’s tough. I’ll be curious to see what other people say.
rose quartz metallic 105lb cover
What about using your invention that reduces the airflow from the air assist fan and slowing the engrave speed?
My next move was slowing the engrave speed!
It totally depends on your art, but a score around the edges might give you that effect more than an engrave ever would…
or pull it out of the machine and run a piece of fabric or cotton ball over the engrave and onto the paper leaving a “smoke” trail.
I think a score around segments is a great idea for getting some char. Also consider this post regarding modifying the air flow: How to manually control the air assist fan power
I think @deirdrebeth has the winning idea – both easy and safe! Increasing char (burn) on paper is sooo close to crossing that thin line from engraving to conflagration… Either way, never leave your GF unattended when working with paper! YMMV, of course.
Good luck.
Thicker paper = more material = more smoke. There are some very thick watercolor papers that might fit the bill.
you might even have more luck with some “char” by using uncoated paper with a little more “tooth” on it, like a watercolor paper. not sure how smooth that rose quartz metallic paper is, or whether it’s coated. but an uncoated, rougher paper would probably retain a little more of the smoke than a smoother paper would.
I have nothing more to add, but I sure would love to see the final product when/if you have permission to publish it.
You could also simulate smoke marks and scorch in the engraved image. We’ve seen people simulate wood grain same concept.
You can create both higher speed and higher LPI and more power, and it will take less time. If you are using variable power there is not a lot of room between 0 and 15%. You want to experiment first, but work with the full width and maybe half inch height in a fairly busy part of the design.
As a bitmap image you can go to 4000 speed and full power and probably be in the ball park at the highest LPI you can be comefortable with. Matching the speed needed to get full power, particularly on wide work will get the job done faster than 1000 speed and 15% power.
Did you ever solve this?
I didn’t realize this was an old post at first, but as I read thru it I was thinking a greyscale variable-power engrave might be the most efficient way to hone in on the best settings. As the actual numbers in the UI are not linear, setting up a shaded rectangle from 0-100% with the actual number being more than desired might help you quickly identify how “dark” it needs to be using that same setting.
Playing with this because it might come in handy for myself…
gradient engrave.svg.zip (2.2 KB)
Not sure which.software you used to make your gradient but if anyone else is trying this beware that gradients often aren’t linear by default.
There’s usually a way to make a linear gradient, you’ll need to look into it.
That’s a good point - I used Inkscape.
But then I tried to apply it to something I thought would be good to engrave and realized I was working with a B&W raster/bitmap, and that’s not so easy to convert as a (say) filled text object would be when I can actually set the “darkness”…
:thinking:
OK, thanks for wasting my afternoon! :rofl:
So I took a B&W image and converted image to path. Then I could adjust the resulting outline fill to the % fill to the desired engrave setting.
I won’t share until I’m confident I can repeat it. And of course, I’m using a “Pro” with >100% power. But I’ll share what I come up with.
