Hey gang.
just did a quick engrave on some oak veneer plywood from Menard’s
it looks really great and the engrave did just fine.
hit a snag when I went to cut it out.
i used the same cut settings I had used from some other plywood. and that was just not quite slow enough to cut all the way through…
so I thought I’d ask here if anybody had used that product already.
If not I will run a trial and post my results.
Don’t know what settings to use on a material? The only way to be sure is to test. Good news! You can effectively test on a thin strip on the edge of your material, it’s fast and easy.
I use this shape to do so (SVG attached):
[Material_test]
Click here to download/save
Or click here for the ZIP: Material_test.zip (3.3 KB)
To use:
Set the first operation to score (the numbers). You’ll use these to identify your cut pieces later.
Set each of the curve shapes to a power/speed combo t…
You’ll have an answer before you get a reply
I will run that when I get back home.
I didn’t see that original post. thanks for the heads up!
Just to kind of reinforce the point - even if you have settings from other people, you should always test your material on your machine. In the case of most products, it’s faster to just run those tests as you will almost always need to adjust them a little anyway.
Keep a small test file (mine is much simpler than above) in your library and you can quickly test any new material.
ya this is true. I have gotten to use Beamer so little I’m way behind the curve on this.
OK folks…
oak veneer MDF core plywood from Menard’s 125 zooms and Max Pews!
for cutting
