You may need to do some extra testing, but here is a wealth of info: Somewhat Comprehensive Testing of Settings for Cutting Paper and Cardstock
Remember to use the set focus tool since you are mounting the paper on plywood. You say you have experienced “just barely cuts the paper” isn’t that what you want? If you are trying to cut both the paper and the plywood, that is a different problem.
