Parametric Box with Finger Joints - Fusion 360 file
A question and a comment.
First the question, I see you saved kerf in the parameters but I don’t see it used. Am I missing where it is used or did it not make it into the model?
Okay, another question, could you run us through your workflow? it is obvious that yours is a bit different than mine and if yours works better…
The statement, I am defiantly not an F360 expert but I do think that long term you’ll be happier if you make one body one component. It opens up certain permissions and capabilitys that working in bodys don’t give you.
