Edit: The strokes are centered. I replaced it with an offset stroke and it seems to have fixed it for all of them but one for some reason. But I would still like to know what caused it.
Any suggestions?
Thanks in advance!
My guess would be what you’re using to make the diamonds is an appearance, rather than an actual node edit - but as @eflyguy said, without seeing the original .svg I’m just guessing.
@eflyguy Illustrator @deirdrebeth I used the outside shape of the diamond logo in the image as the outline @cynd11 Hi!!! Haha. Expand appearance is greyed out
Looking at the raw SVG code, none of that is even there. Was the file replaced?
@JeremyNielsen : how did you get the original shape for the diamond?
Just a guess here but it looks like an appearance-type thing, possibly a warp command or something to the original shape? You made the copy and then subtracted out the text, which forced it to redraw the code for the shape.
The reason being, in the SVG code, this is the code for those shapes - so they are all being displayed as they should for what the code is.
Interesting!
So I duplicated the diamond icon and deleted the inner shapes so I just had the outline and then just made it bigger. I’ve done the same thing a thousand times without this weird bloating.
