Thanks. That’s wonderful.
Just bookmarked these two rabbit holes!
I just want that original as a print for my wall
OOOOH have you downloaded this?! I just happened on it by accident tonight. It’s a ton of free packaging die lines in a single 114 pg PDF and they are fancy schmancy ones I have never seen and can be made rather sturdy! There is a version 2 with more you can see on the same page as well. They could be color coded to do on a laser or cut on a SIlhouette once vectorized… make all the things
The second one has even more impressive ones… I mean who doesn’t want to make Tetris inspired boxes you can package your things and play with at the same time. haha https://issuu.com/designpackaging/docs/packaging-dielines-free-book-design_7fb37ab8a1c323
Thats amazing. Good share. So many things laser cutter can do. Better than 3D printer
great find! - dowloaded it
thanks!
For sure! I have a 3d printer at my disposal and have YET to use it even though I should learn it… I just think of how I can do it with the laser… it’s so much faster. lol
Totally depends on what you are making. I print multiple Kg/month (sometimes per week) and also am going through a ton of materials with the laser. It’s like arguing that a screwdriver is better than a wrench. Sure they both turn fasteners, but good luck changing your tires with a screwdriver, or opening your laptop with a wrench (well more than once
There are many things you can 3D print that would either be absurd to make or impossible with a laser, and the materials are different, while there are many things that are impossible/easier/faster on a laser cutter. If you only work in 2.5D then yes a laser is a great tool. but if you transition to full 3D it’s an even mix.
For instance the holster project I showed a few days back is a perfect example. I am making a very crude/quick prototype on the laser since I can get answers in minutes, but the final version needs to be watertight/and 3D filleted (and autoclavable so that means Nylon), so that would be crazy with a laser for final prototypes once the basic shape is done.
I will say the learning curve on 3D printers is steeper, and you constantly are battling a more complex of issues, but they are equally useful devices depending on circumstances.
Very well said…
Surely laser cutting machine is quick and stuffs made out of it can go straight into selling. 3D printed parts has after process as well but no one can beat it for 3D form.
Laser cutter is so useful.
Yes agreed.
There are plenty of parts I print that have no post-processing and go directly into use. Depends on what it is.
