That is really sad but fascinating.
We’re glad you found the solution! Your findings will be so helpful for other Corel users.
In this print, the location of the coins that printed might not represent the entire printable area. If part of a coin was outside of the printable area, the entire coin did not print, including the part that was inside the printable area.
If you delete one column of coins then recenter the group of coins, you might be able to fit more coins inside the printable area.
Generally speaking it’s another step Corel users should think about is always checking the SVG vs the CDR file and not assume Corel did the translation correctly.
Some things make Corel more useful than Inkscape (like the other discussion about Inkscape including the stroke thickness in the object size vs ignoring it so you don’t need to make allowances for stroke or auto translation of text to paths). But for other things there are trade-offs that have to be made. Not a GF issue but something we’ll need to learn over time.
I’ve reported it to Corel so potentially it’ll get fixed in X9 (hope springs eternal ).
Thanks for the info!
