I was fortunate enough to be able to attend the Seattle Maker Faire today, and meet Dan and the awesome Glowforge team! Here are some photos and video links from my time with them:
Just updated the original post… I made a pendant with my family’s Celtic knot on it for my wife. Video of the making should be up in 20 minutes or so, video of the demo should be finished uploading in a couple hours.
@dan at about the 9:48 mark you said the camera can see the entire 18"x12" bed of the machine.
Did I miss something?
Does this mean that the 20"x12" requires the tray be removed?
If so does this mean I can only get the full use of 20" passthrough by removing the tray?
So, I heard @dan say a depth of 2.5" object is possible. Is that correct or did he misspeak? Last I heard it was a 2" object at most, and that was even larger than the originally 1.5" dimension. If true, this is huge!
I believe it’s a 2 inch tall object (max) that can be engraved, because you can’t have the object pressed up right against the laser nozzle, although there is 2.5 inches total clearance. I think the GF needs about half an inch of space for clearance and focus.
Otherwise the little flame that shoots up when you engrave or cut might be charring the optics, setting things on fire, and other Generally Undesirable Laser Behavior. (GULB)
Plus or minus half an inch of course, I haven’t seen one yet.
(Could be totally wrong, that’s just my interpretation of the tasty clues.)
she is using a a Surface Book I know because I have two one is a i7 with NVidia gpu and the other a i5 without nivida. As to the specific cpu and gpu for her Surface Book I don’t know, she was also using the included Microsoft pen to do the drawing with. But for the with she was doing a NVidia dedicated gpu would not be needed. I also have a surface pro 4
How do you like the Surface Book? I want to get one, the one with the dedicated GPU, but the cost is so high. I might end up with a Surface Pro 4 and forgo the heavy lifting in terms of ACAD and such.
Thanks for the pictures! Glad to see some examples out and about now. I am wondering though, are the bodies on those demo’s still the 3D printed versions or did they appear to be injection molded ?
