I made this a while back, and just got asked for measurements. Decided I’d just share my design file. Not sure why I can’t upload the SVG file, but here’s the .cdr file.
Crows Nest Cat Tree.cdr (127.5 KB)
Crows Nest Cat Tree.ai (113.0 KB)
thanks for sharing. if I still had a cat, i would be cutting this already
Thank you.
That is so stinking cute!
Whoa, that’s so nice of you! Thanks.
I believe it’s because it didn’t have any size, everything was relative. I believe this is the correct size - though I did rearrange a bit to use up larger pieces of material:
(the rest of the bits are off the 20" x 12" art-board)
Thank you so much for sharing!
For reference, I made my base circle 18.5" in diameter, and put another piece under it that extended 12.5" from the center of the circle to the wall. I then put a 2x2 strip on that so I could screw it through to the baseboard for stability. Glad you like it!
How kind of you to share—thank you!
Thank you for sharing … it is very cute!
Thanks for posting this. I missed it the first time around, so it was a good opportunity to look at the kitties and go “awww!”
This is so cute!
I had to look at this as I wasn’t sure if it was the cats or the cat tree that were pirates. My best guess is both?
All cats are pirates at heart
Or terrorists
