Is it ok, to use plywood?
Welcome to the forum.
Which machine do you have? Glowforge does not recommend medium plywood for the Aura.
Material Capability
Can safely print on any laser-compatible material, including the examples below. Glowforge recommends using Aura-compatible Proofgrade® materials for smart settings and perfect results. Proofgrade materials are specially sourced and lab-tested for creating prints safely at home.
Note: Most Proofgrade materials work beautifully with your Glowforge Aura, but we recommend against using Draftboard™, medium plywood, and clear, white, and blue acrylic. All other acrylic colors, and both Light and Thick plywoods, will work wonderfully. Learn more about laser-compatible materials here and see our collection of Aura-compatible Proofgrade materials here.
one problem with plywood is that there can be voids that are filled with “goop” that the laser won’t cut.
