PNG files printing smaller than Size in Illustrator
I have been trying to make aluminum business cards, so I laid out my file to engrave in Illustrator. The size of the file is 3.5 x 2 in illustrator and prints on a printer fine, but when I GF it is comes out about 75% of the size. I am using a .png file to engrave. Can anyone help. I have seen a lot about .svg files, but nothing about .png
That might have something to do with the settings that you are using for your SVG file.
Are you using Save As or Export? (Save As used to be recommended for fewest problems, I’m not sure whether that still holds or not.)
Sounds like the 72 dpi versus 96 dpi problem.
So I take it you’re just exporting a PNG out from Illustrator?
The problem is that images don’t use actual real units. So you’re just exporting out an image at a specific pixel Width and Height and then it’s left to whatever software app to display based on pixel units.
Your best bet would be to size it appropriately in Illustrator and then export a SVG with the PNG(s) embedded. That way the SVG specified the image size in specific units.
Ok, these are all very helpful. The dpi thing did help, thanks @josephtpage
The other suggestions for the embedded .svg file worked as well.
I have not reprinted yet, but it looks good on the screen. I will give it a try and show a pic if I can. Thanks Community
I’m glad you resolved it! I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
