wikipedia has one:
Not gunna lieā¦I probably spent a solid ten minutes just staring at that first photo. And then to hear that itās only 4" big??
Thanks so much for not only sharing this amazing design, but also for showing the benefits of leaving the masking on the final piece! I would have never thought to leave it on, but after seeing the two engravings side by side I think I actually prefer the one with only selective weeding. To me, the smoke on the masking gives it more dimension and makes the weeded parts pop even more in comparison. Amazing work!
No problem! Im really loving the selective weeding as well! I really cant wait until 3d engraving is available to pre-release users. Then I can start making them with actual dimensions like that! so excited for that
Oh man, if youāre already changing peopleās stance on glowforge now, I can see the fb laser groups just exploding when you get some 3D engravings done!!
Yep. Hereās the direct link to the SVG file - you can grab different resolutions and pixel sizes from here:
grab the SVG, then you dont have to worry about resolution and pixel size =)
Yep - but I figured if someone was SVG challenged from a software standpoint they could get a higher rez PNG. Or if you want it for computer wallpaper and are too lazy to import & export
Nice find though. I wonder if thatās the source that all the laser manufacturers use for their samples? Epilog sends one out with their brochures too.
I imagine you could get a similar effect with leaving the masking on with a light ply where you want light (say the maple) and then applying a light stain to the exposed areasā¦ That way the texture is wood all the wayā¦
/uploads/db6859/optimized/2X/5/5af28359c7b8dc0d11115958cbda3aff992b0c86_1_690x452.JPG
Pretty much like that?
Here is another one. Perhaps a little cleaner.
http://manmademayhem.com/Aztec%20Sunstone.svg
So if itās 340, that means we have another 4x in resolution to go? Goodness.
(Yeah, I know, not really 4x, because the spot size is somewhere smaller than 8 mils, so youāre really just placing your ābrushā with much higher resolution than the bursh size, hence more detail only in some conditionsā¦)
I just got some new masking in last night, so im going to attempt to do some multi layer painting/masking to see how it comes out. Obviously will post when I have results =)
Nice. Thanks!
OMG. The detailsā¦ THE DETAILS. Iām so excited!
Yeah, that one is much nicer! The Wikipedia one is a really bad rendition, IMO.
Thereās several of them out there, but I havenāt been able to find a very detailed vector-based reproduction of the original. I also havenāt been able to find a single detailed 3D scan/model of it. If anyone knows of one, Iāl love to take a look at it!
Iāve been looking for the same! No luckā¦
Beautiful.
Pretty new to this stuff, though. What is meant by āweedingā?
pulling off all the tiny bits of masking thats covering the piece. it takes foreverā¦ @dean 's tape trick helps a bit though.
Ah, thanks!
Soooo friggen awesome!!!
