There a couple people were wondering about avg. power consumption on a glowforge.
I did a sample cut on non-proofgrade cedar (1/4") and metered the process.
Now, this is a moving target. This is equal to trying figure out the exact amount of prints you can get from a ink jet cartridge. There are a lot of variables. With that said this is a ‘rough average’ of what the consumption ‘could’ be like.
And the usual disclaimer about the fact this is a pre-release and the final could be different goes here.
The values were pulled from a power metering sensing z-wave outlet. I’ve setup my HA (Home Automation) setup poll it every second.
So with the machine on an idle (Powered up and doing nothing)
This op was a two parter. One cut, bunch of engraves. I broke the engraves apart so I can have time to take pictures while this is going on. Otherwise it would have zipped thru this too fast.
Nice! Using a remote was becoming a real hassle Although as cranky as our Alexa is she’ll have me watching cartoons and civil war documentaries regardless of what I ask for!
Previous number were peak power. Usually when you turn electrical stuff on the power demand spikes and then settles out very quickly. You have to spec most electrical components for peak power.
With that powermetering, can you set it up to turn another outlet on when a certain power leveling is reached? E.g. turn on booster fan in vent piping if power to gf is larger than x watts?
This exactly what I am doing. Anything over 80W turns it on. <79W it waits 45 secs then shuts it off.
With the added bonus of if the smoke detector in the office goes off. It kills the power to the glowforge and sets the booster to full power until I address the trouble code.
This is absolutely filed in the DO NOT TRY AT HOME category. Nor I or glowforge will provide any support for this configuration. But in testing the glowforge under its own power was able to push open both blast gates and the veins on the exterior with ease. My interior to exterior ‘piping’ totals out to 20.5 ~ 21.5’
