I don’t know how this happened, it might be an error in the design itself, but if you look at the thumbnail, you will notice that the horizontal bar and the 2 “V” shapes above it are a slightly darker color.
I suspect that design has an exact overlay for those parts, which will cause the engrave to cancel out there. In order to fix it, you would need to export your file and correct it in something like Illustrator or Inkscape. (Ungroup and Delete those duplicates.)
It should, but I don’t think they’ve gone through and vetted every one of the 2 million or so designs.
(That might take a while.)
Quicker would be to pick another diamond shape…I tried to spot that one exactly to check it, but there are too many that look exactly alike to me. I’ve guessed a couple of times and those weren’t the same diamond shape…they were fine.
On your screenshot, the image on the left looks like it doesn’t have the top of the diamond. Did you move the design? None of these designs are held together so if you move them and the whole image isn’t selected, little bits get left behind. When images are smaller its more common to lose bits when moving. It’s very frustrating and I’ve had this happen quite often.
Thank you for reaching out about the trouble you had with the Premium diamond design. I’m sorry to hear you had some issues getting it to print, but glad that @Jules was able to help you out.
I’ve located that particular design in the catalog and will let out team know about it.
Since the issue looks to be resolved, I’m going to go ahead and close this thread now. Please don’t hesitate to reach out again should you need anything. We’re happy to help!
