I think I need a new printer head lens, is it possible to get another? Cannot remove all crud from lens
is it posible to order more than 1?
I have done both, most of it has come off but want to gey get one before I have a real problem, how do I order when I can
Have you tried soaking the spot in alcohol or I use a small drop of Windex for about 3 minutes…
You can order as many as you want if they are in stock, unfortunately they are all sold out. If this is under warranty they may limit it to one…
Yes but they’re currently out of stock. You can leave your email and they’ll let you know when it’s available again
OTOH if your
is under warranty you may be able to get one direct from CS. They’ll respond here on Monday.
Hi there - I see you already emailed us about this and we’re working on it there, so I’m going to close this topic.
