Printer Stand
Here’s another practical cut. This is a 14" square printer stand with space for a ream of 8x10" paper underneath. It’s designed so it can be cut on a Basic; Pro users can combine the top pieces into one, if you want to.
Here it is in use (wall pocket pattern is available here):
Side view, front view, and underneath:
I didn’t include sizing squares this time, but the pieces are all 14" long, so you can use that to check the size. It’s sized for 6mm Baltic birch, and you’ll need a hammer to tap it together.
Middle support, front, and back (blue line is scored, all others cut):
Printer%20Stand%201
Sides (red=cut, blue=score):
Printer%20Stand%202
Top front:
Printer%20Stand%203
Top back:
Printer%20Stand%204
I love your practical cuts, even when it’s something that I will not be needing .
Thanks for sharing.
Thanks for the share! I had noticed it when I was checking out the wall pockets. :slight_smile:
I meant to post it sooner, and kept not getting around to it. :stuck_out_tongue_winking_eye:
Nice! I was going to ask if it had sufficient support but then I saw that you did include that, so I’m guessing it’s rock solid. Nice that you included decorative ventilation holes as well.
Thank you for sharing a functional design.
Looks great! I always enjoy the extra little flourishes in your designs.
Ditto! I’m liking that side pattern… :sunglasses::+1:
Thank you for sharing!
