Before this upgrade you use to be able to add a design from your library to a current design and print two at the same time. Now you can only add art work. Do you really have to print one, wait for it to finish then go back to the dashboard like you are doing a new cut but leave the material in the printer? If so this is very poor planning on the developers side.
No, this was answered early today. Make sure the design is highlighted in GFUI, press Control-C, then press Control-V and place the copy where you want it.
And if you are talking about loading different files at the same time, you can still do that. Click on the + sign and then click Upload from File and then select the one you want. You can not add catalog files though, since they are not files on your hard drive.
Thanks for sharing the Glowforge keyboard shortcuts, @gamn1958, and for the tip on loading multiple files into the workspace, @tjones!
Iām going to close this thread - if you have other questions, go ahead and post a new topic. Thanks for letting us know about this!
