I have a client that is interested in having me laser beer coasters with their logo.
Can someone suggest what material or # cardstock would work?
Thanks
Thanks
There are many options for cardboard coasters on Amazon and similar sites. Depending on the client’s budget, cork coasters are also available. The client’s budget will determine the best choice.
If you want to cut them out yourself, look for something called coasterboard.
It would probably be cheaper and easier to just buy the precut coasters like dklgood said.
I only know what it’s called because I was gifted boxes of the stuff, and I went down a rabbit hole trying to find info about it. I have no idea where the gal I got it from got it, but she used it for die cutting. I’m doing the same with it, but also letterpress and coasters.
I believe it has another name too, but coasterboard will get you there
Thanks for the input guys. I didn’t what to call it and found several options online now.
You have learned a valuable bit of information. Knowing what something is called makes it a whole lot easier to find. ![]()
“Chipboard” is great and economical, but it gets really smokey - if you have a cheap light-tack masking it works really well for that kind of thing.
Chipboard is a terrific material. I use it to prototype 3d things.
