It could be wifi related. Try using a phone as a wifi hotspot for one attempt, see if it makes a difference.
Thank you for your tip- I actually always use a wifi hotspot for my connection!
Ah, well in that case the dev. team will have to look into it - probably by looking at logs, so if you can note the time and timezone of your attempt(s), that will help them find them.
Hi everybody!
First of all, thanks so much for all the feedback youâve provided so far! The team has been reading every post.
Next, we have a few Pro Passthrough updates going to beta testers today. Refresh your browser to get these improvements:
- The button on your Glowforge will now light up throughout a Pro Passthrough print to indicate that your Glowforge is busy and you shouldnât lift the lid. The button will be lit solid while your Glowforge is printing and taking pictures for alignment. The button light will turn off when itâs time for you to shift your material, and then turn on again until itâs time for you to confirm the alignment. Once the next part of your print is ready, the button will blink as usual.
- We released a fix for the issue causing âPrint Expiredâ messages. (@marleeshealy @desireecollins22 If you continue to see this message, please let us know.)
- Your Glowforge can now enter sleep mode while waiting for you to shift your material. If the lights inside your Glowforge dim, you can wake up your Glowforge by simply pressing the button or lifting the lid.
Let us know what you think!
This is great. Saves an extra trip back to the computer to advance to the next step.
Hey Penelope!
I just got word yesterday that my adjustable table arrived at Menardâs. it is going to be the INFEED support for the passthrough operations. So Tomorrow I should have things all assembled and rearranged and be able to get back to running. my previous support was just NOT stable enough.
Great!! Thank you!!
My most recent update is that I did not see âPrint Expiredâ!!! I cannot get it to align automatically. It seems to freeze on the inspecting stage for 10+ minutes. But I see this is improvement, at least for me. Thank you!
I tried my hands on another passthrough project yesterday. It went flawless. And I mean everything. Alignment was precise, calculating was fast and the machine cut like a hot knife through butter. Really great to not have to worry about anything.
For workflow I would suggest to be able to work front to back instead of back to front. Shouldnât be too hard in software.
Iâm having trouble with one segment of a passthrough print not cutting through the material while other segments in the same print cut through just fine.
I have printed on PG Thick Draftboard and on PG Medium Maple Hardwood. The file is only cuts, no engraves or scores, and is 35.5" long x 6.5" high. On the Thick Draftboard, all segments cut fine except for the last one, which only scored and left a few small pinholes. I cleaned the lensâit was surprisingly dirty, but not without reasonâand mirrors, then tried again with the Medium Maple Hardwood. The first segment didnât cut through, so I stopped and sent the âgift of good measureâ to test on the same material. It printed beautifully, so I tried again with a new piece of Medium Maple. First segment cut okay, but not great, but then the second segment cut beautifully.
This file has been able to print (I successfully printed a full-size test before making edits), so Iâm confident the file isnât the issue.
Iâm seeing a lot of overburn marks on the masking when the cuts donât go through, and very little when they do, so I suspect that it has to do with the focus. Iâm using the standard settings since itâs PG material, and pinning down the edges with the Honeycomb bed holdown pins on the first cut, but relying on the passthrough slots for subsequent segments.
Any ideas?
Well I did a 4 piece room divider. The auto alignment work great on all but one area. One of the pieces had a area that only had a few lines to cut. Two were right near the edge, another also close to the edge being about an inch in. Leaving just one near the center. I tried a few times and it wouldnât auto align. (And I had zero luck manually aligning)
I decided to add a âpendantâ to an area near the center so I would have more lines and even some engraving to help line things up. First try and it was able to Auto align.
Not sure if it what made it work â or it was just luck.
Iâm super excited for this to get out to the community. It sounds like this has been pretty successful. I too was hoping I could avoid that nightmare of breaking up large designs and let the software take the wheel. So I guess for now Iâll just party in the community group and cross my fingers that one day I get the beta upload so I can test this too. I have some orders on hold (for personal family/friends) that understand Iâm waiting for the upgrade. This is like waiting for paint to dry though. I REALLY want to try this. Has anyone had any issues with a design being too overly complicated and it not working or has it been pretty clean. From the discussion above it seems to be working well
We all had some issues when the initial tests were running I think, but I was getting 100% success before it was opened for Beta testing, so you likely wonât have any insurmountable issues.
(And I hope they are still expanding the Beta. Might be a week or two though, they are working on multiple things simultaneously these days.)
If you do get picked to beta test, remember to carefully read the instructions they give, pin the material down flat in the machine, and always start with the material and design up against the left side.
Can confirm, beta invites still going out as of 6/5. Only played with a few simple things so far but theyâve all been perfect, seamless transitions to the naked eye. The process isnât exactly speedy but still faster than the manual methods.
Thatâs great to hear. i have 5 large pieces waiting to be printed on in my back room and Iâm just so antsy to get started. Been doing some fatherâs day projects to keep busy but I really want to get into larger stuff. Thanks for replying
Do you have an ETA or rough release date for when the general public will get this feature? I applied for the pass though beta but never heard back, not even a confirmation email. I fear this will go though the same way snapmarks did for me (never saw them), I anxiously awaited the release then⌠nothing. Iâve had my GF for nearly 2 years now and to say I am frustrated with this process would be the understatement of the year. I bought the pro specifically because it has the passthrough slots.
So far I have been disappointed sitting on the sidelines yet again waiting for a featureâŚ
-G
I had the passthrough beta enabled on my machine, then I had my machine replaced under warranty, but the beta was never transferred to the new machine, and I desperately need it in order to finish a project Iâm doing for someone, and I need it now! This should have been done automatically. I emailed support, I filled out the application again, and now Iâm writing in this forum post. It shouldnât take this long for support to actually respond. Most companies respond to inquiries within 24 hours, and it has been 3 days. Glowforge, if you canât cater to your customersâ needs within 24 hours, then I really think you should hire more staff.
UnfortunatelyâŚ
This is a really common gripe â Iâve made it myself â but I wouldnât expect them to promise 24h turnaround especially on something that is beta.
Not every machine is suitable for the beta, so it wouldnât be automatically âtransferredâ. I believe they would need data from previous prints, the camera images, etc., so a brand new machine would likely not provide the data they need to determine if it is suitable. You would need to have been using it a fair amount for other prints. Support doesnât handle the process, it is the dev. team - posting here is the fastest way to get their attention.
Finally had my first and second go at the passthrough beta. Picked out something with a little more detailed and a circle. Used 1/4" thick Draftboard(GF stock). I adjusted power to 121 instead of 132. Too many have not cut all the way at 132 power.
First go through did not match up even close, used manual and
Ran a quick camera calibration.
Second go through came out close to perfect. Slight minor imperfections which can be fixed with a minor 2 second filing. Not bothered by this as the piece is to be painted.
It is 18" in diameter.
Used my two adjustable rolling table saw stands for front and back support so easy peezy.
Almost forgot to mention I was using a piece of board that was 20" wide X 48" length.
Properly supported material to address keeping things flat is a must.
Also I throughly cleaned the lens, printer head, head Window, laser window and the wide angle camera lens.
Just an update on our pass through. So far 4 projects 60 inches plus and every time we have to manually align. We pause wait 20 minutes while it says taking pictures and then move on with our days. At this point the software looks promising, but No matter what file we use, or how patient we are the results are the same. Any advice is appreciated, at this point just going to manually align.
