Pro Passthrough Slot
The Pro also includes a more powerful laser and better cooling. I think I would consider the pro for the cooling and stronger laser over the pass through slot. If they had a basic with the upgraded cooling I would be on the fence about that + airfilter.
Lets be fair though, nobody wants a pro for the slightly better laser or cooling, they might make a little bit of sense for those planning on running non-stop but that’s about all, you can’t cut or engrave anything extra with the pro that you can’t already do with the basic. The reason for ordering the pro is the pass through facility with the implication that you can run items of any length through the machine for large work. In reality this feature is very limited to thin materials only.
Maybe it’s my lack of knowledge about what I can do with a laser and specifically the 40 vs 45 watt.
But I’m pretty sure my saying I would does make 1 person more than nobody.
Ok I apologise, I am sure there are people out there who are buying a pro for that reason but the vast majority fall into the same category as me, wanting it for the bigger area. I am sure this was your main reason too wasn’t it? You didn’t shell out an extra $1500 for 5W of laser did you?
honestly, the pro cost wise is a significant stretch for me. But I have a history of picking a slightly cheaper option being horribly disappointed and then having to spend significantly more to get to the functionality I really wanted.
In this case with the crazy heat here in my part of the Southern US, me being a cheapskate with the air conditioning and burning out a few electronics before their time as a result. Yeah the cooling really caught my eye.
But I also posted here because I know how little I know about laser cutters and can stand to learn from everyone here’s differing views.
For me the pass through is a nice to have but not a real consideration in my decision to go Pro. Mostly better cooling, improved optics and additional warranty. The Pro is designed to run for longer periods and yet has twice the warranty. That implies to me it may be mechanically and electrically more robust. Of course it’s always possible the additional $1500 just pays for the longer warranty but I doubt that was their business plan.
It only seems worth it to upgrade if you going to use the laser a ton, for me thats not the case and I just wanted the passthrough, but since its so small it doesn’t have much if any use for me
ā€œFurnitureā€ related… the computer monitor stand in the promotional video is something which the Pro can make, but the Basic cannot.
Well, for some monitors at least. Not sure if that specific one pictured is more than 20" lengthwise. And MAYBE it could fit in the basic on a diagonal. But if the total width is meant to allow a keyboard to slide under the stand, then the keyboard in front of me right now is 18" long, and the legs on the stand look to be well over 1" wide (plus you don’t exactly want a tight fit here).
So to make that stand, you are cutting multiple thin sheets of wood, staining them various colors, then gluing them together. And there you have furniture which is laser cut, and needed the pass-through.
I plan to mostly be making enclosures and other structural elements for small demo apparatus. So in my case 1/4" is almost always good enough, or gluing a few sheets together is great if 1/4" is not strong enough. And many times I will want to make something rather tall or long, at least as a stabilization/alignment element.
Now… if you want to make a couch, or a coffee table, then doing the entire thing in the Forge may be unrealistic. But you could just do the decorative bits here, and do the structural with more traditional methods.
You designs on skateboards may not be able to be laser etched, but you can still make nice stencils to spray-paint through, or even guides to use old woodburning techniques with (I assume people still do woodburning, but I haven’t seen the stuff at all since I had a kit as a kid, so I call it old)
@jacobturner hit a nail on the head, mentioning the stencil option. As launch was approaching, I was perpetually telling people that if the GF can’t make a thing, it can assist in making the thing to make the thing. :smile:
I know the purists in the audience may cringe, but there is no shortage of furniture that is made out of slabs of cheap wood with a thin veneer of nicer wood over it. If you are willing to accept that as an option, the 1/4" limitation becomes less of an obstacle. Also, there are options to laminate a Glowforge - engraved 1/4" layer (possibly with Glowforge - created inlays too) onto a thicker slab of the same species. As long as you’re not using a species with widely variable grain and coloration, the seam could well be nearly invisible.
I also bought Pro for the passthrough.
So GF confirmed that the slot is 3/8" and designed for 1/4" material. It seems rediculous not to increase that to 1/2" - anyone know why? But at least we may be able to use maybe 3/8" for cutting…(?)
I said this elsewhere, but just to be sure it doesn’t get missed - don’t buy the Pro (or the Glowforge, regretfully) if you need to use material thicker than 1/4" with the passthrough. Hopefully this was clear in the specs, and if not, my deepest apologies.
The tech specs on glowforge.com don’t actually say that the height restriction is 1/4" (site copy is pasted below). Only the Material Capability section mentions 1/4" as a height restriction, except where the material is flipped, and is not in the context of the pass-through:
PRO UPGRADE
Passthrough slot allows the use of material that’s 20ā€ (50.8cm) wide and as long as desired
Passthrough software uses the camera to maintain alignment as long material is pushed through
Laser tube is upgraded from 40W to 45W
Higher quality optics provide for more beam power at the head
Upgraded solid state thermoelectric cooling
MATERIAL CAPABILITY
Thickness: Varies by material; can cut most 1/4″ (6mm) plywood and acrylic on one side; twice as thick by reversing and cutting from both sides with optical alignment
I personally don’t think I’ll have an issue with it–I can’t wait to see what I can do.
No upgrade for me then, Maybe the glow force 2 can make the passthrough slot a more usable size. Like its said above its not listed anywhere on the specs for the passthrough size.
Not a problem, the basic is fine for me! Still very excited
I bought the pro version and can live with the 1/4" limitation on the pass-through slot. But I sure would feel better if I knew that there was some technical/economic reason for that limited height, and that it was not just an arbitrary design choice.
Good catch. Fixed that, thank you!
The cynic in me wonders if the passthrough slot being only available on the Pro is a money grab. From a manufacturing cost perspective, it would seem to make sense to build only one enclosure and put the Pro or Basic components in it. But then, how many people would downgrade their order to the Basic if it was built with the same pass-thru slot enclosure as the Pro?
Personally, I would love the pass-through slot but, as a hobbyist, have no need for the other features of the Pro.
We’re a company. We have a few things to do here. Grabbing money is one of them. Making you awesome products is another. They are related.
Understandable, but I might just have to take a Dremel to my enclosure once my 6-month warranty is up. :wink:
