Like the title says…
At first, I could cut without using the set focus option and just entering the material height.
Then, if I didn’t set focus, the material would not cut all the way through, no matter what setting I was using.
Then, the set focus option started to send me an error message (Error with your Glowforge, close and reopen browser)
Then, the set focus option would work for 4-5 cuts and after it just would not work at all anymore.
Then, the button became orange without having cut anything and the app was stuck on focusing.
I checked the wifi as instructed
I cleaned EVERYTHING as instructed (all mirrors, lenses, circuit boards and fans (including air assist)
I put EVERYTHING back as instructed
So I took photos and here we are…
Note: While taking the photos, I noticed that a pin was missing from the printer head’s white ribbon (on the far right)… I KNOW this is bad, but is it SO bad that I can’t use my machine anymore? Is it the reason it’s doing that?
Thank you!!
