I wanted to remove the score lines to shorten my print times, but any attempt I make to alter either PDF or the Ai file, I loose the vertical lines that actually cut them. I see them in illustrator but as soon as I upload they disappear. Please help.
Instead of modifying the art, change the score step to Ignore in the GFUI - no manipulation required
Thanks, @deirdrebeth - that’s right! The “Glowforge Ear Savers” and “Glowforge Ear Savers Sheet” designs both have the Cut and Score steps grouped together, so all you need to do is set the “Score” step to “Ignore” if you’d rather remove them.
