I spent quite a bit of time putting in all the custom settings for each section on this project just to find that once I go to print, it just times out. So I ended up ignoring about 15 processes and that went to print just fine. Is there a limit as to the number of processes that the Glowforge can handle? It’s odd that it can handle 95 processes but not 112…?!
My understanding is it’s more about the size of the overall job. I have seen estimates that the limit is around 3 hours of processing time. I had a discussion with support about this recently. It seems to be an issue they are working on. In the meantime, your workaround of “ignoring” some of the processes on the first pass and then switching which are run and which are ignored is the best option for complex jobs.
Thanks John. I’m pretty sure you are right about the 3 hours because after ignoring enough processes it brought it down to 2h 44 min. So I know the other processes bumped it over the 3 hour mark. The only issue with ignoring is that it erases your settings when you set it back to manual…
Your design is both functional and lovely. But another way to reduce the time would be to either change the shape of the ovals (making them potentially smaller), or make the entire thing smaller until it works.
You can also reduce the LPI to help shorten the required time.
I love the test pattern matrix though. I had been thinking of doing the same thing to build a reference library for my non PG materials
Yeah, agreed; I’ll make it smaller. I also don’t really need for it to do full power at 10 speed so there are some processes I might want to ignore anyway.
