As it sits now, PG loaded (or unloaded- as in you manually pick it from the material picker), when you goto ‘manual cut/engrave/score’ it populates the settings it was going to use.
Unless you switch to ‘unknown…’ (PG not loaded) it will not let you run the op. But at least you can see what it was going to use and use that as a baseline.
