Proofgrade material suggestion
Hi all,
I don’t know if this is the right place to post this or if this has already been discussed, but is there anyway to have a one inch or one centimeter grid printed on the sticky sheet of paper on the Proofgrade materials? That way, I’d have a better idea of how big my designs are on the app. What do you think?
There’s a ruler in the UI already, so maybe a better idea would be to have the grid in the UI instead.
If you zoom in and pan you can place your work in the upper right hand corner of the view and get a pretty accurate measure against that UI, and that is at least as good as a grid as I for one have enough trouble seeing the edges of the design as it is.
Thanks for the suggestion @omar.bakht!
I’ll make sure the team gets them.
