Thanks for letting us know. I’m sorry that your print didn’t come out beautifully! Thank you for taking the time to do some initial troubleshooting. Can I have you check a few more things as well? If you see a step you’ve already done, feel free to skip it.
To cut successfully, there are three important things to check. First, your material must lie flat. This requires a clean, properly installed crumb tray and flat materials. Second, there must be no obstructions, dirt, or damage preventing the laser light from reaching your material. Third, your design must be set up properly - for example, with lines that are fully on the material and that are set to cut. It’s hard to know which issue might be affecting your print, but if you follow the instructions in the cut-through troubleshooter, we’ll be able to get to the bottom of it.
Once you’ve inspected and cleaned, please try another print. We included an extra piece of Proofgrade Draftboard with your materials shipment for troubleshooting. Please print the Gift of Good Measure on that Proofgrade Draftboard and let me know the result. If it doesn’t print well, please let me know the date and time of your print and post photos of the front and back of the print. If you’d rather not post the photos here, you can also send them to us at support@glowforge.com.
