My sisterinlaw suggested some type of scarf pin, however that would be used. Is that like grandma’s cameo brooch? Well once we get the 3D in the wild, the cameo will be that thing hip again.
And here is the swarf from a few of the earrings. They are more close to the lines of the logo. I was seeing the as the negative space.
Go look at the ruler pic. It’s the same there but tighter. I can inset slightly and make it exact. I am vectoring through so I have to do the kerf thing. (takes glass of favorite beverage required whenever need raises its ugly head. On the ruler it is vector engraved so you can just stick the bitmap in and it’s exact. I vectored the logo a long while back for the Glow Ray. The in the ruler from Glowforge is a deep engraving that almost goes through, but not quite. So you get a real contrast with the walnut. It’s is a good design.
Addendum: note grain direction change between charm and earings. Stronger for that hole
Relating to the ruler, it was not possible to tell from the video if the ruler was “exactly” the same spacing over the 6" distance when compared to your carpenter’s rule? It did not appear to be which could be either parallax or the cut was in fact not exact over the full length.
I am reflecting on your inverted teardrop shape. I went with more curves and a point. I messed around with that for a while. Not sure if I like my point.
If you don’t mind me make it simple and following along the straights to a point, I’ll make a few that way.
I totally agree! I’d like to be more verbose in my agreement, but I think it might lead to topic derailment. If I spot a new splinter topic about our silly (yet established) tradition, I’ll definitely join in…
(attempting to nip this in the bud instead of contributing)
