Proofgrade thick basswood ply not cutting through
That can happen if there is any warp in the material at all. Make sure the material is flat against the tray in all spots…I like to use these honeycomb pins to keep the material pinned flat:
Alternatively, you can specify a second pass be cut, or slow the cut speed down by 5 or 10 points. Go to the Manual settings and you can adjust the cutting speed using the little slider.
