The wood was what I had lying around… probably from Home Depot. It was 1/4" walnut for the outer layers, and 1/2" poplar for the three inner layers. Cutting 1/2" is pushing it; probably better to go with six 1/4" inner layers.
I used regular wood glue for the face joins. I forget which variant of Titebond it was.
The edges required extensive sanding; by the time I was done, the outline had changed slightly.
If you’re going to try it …
Be sure to test the slot width and depth for the teeth
Use a brass pin for alignment, not dowels. Dowel widths aren’t consistent enough. Make sure the hole is tight-fitting.
I’d suggest the following assembly order. (I got this wrong the first time.) Apologies if this is hard to follow.
Align and glue the inner layers first, taking care not to glue the brass pin (since you’ll have to remove it later). When it’s set, sand and finish the top edge of the inner assembly.
Align and glue the right-side outer layers together, and the left-side outer layers. When both those side assemblies are set, align them together (without gluing), and sand the top edge.
On the left side assembly and the right side assembly, finish the portion that is going to be exposed on the inside (the interior walls). Might help to cut out a piece of masking paper the same shape as the inner assembly, to avoid getting finish on the part that will be glued.
Then align & glue it all together, and sand the exterior sides, bottom, and ends. Then complete the finishing.
modify the middle “spacer” pieces to include a space for BBs
That’s a good suggestion. You can also get finer shot than BBs, to fill the space a little more efficiently. I’ll probably require adding a couple more layers to make some space.
The only thing i can think of for weights would be the ones they sell at Michaels for the derby cars- we used to buy them every year for daughters girl scout pinewoord derby. And then wheel weights for car tire balancing, since they are flat and have squishy tape on the back.
But that’s all my experience with low profile weights. I added some once to a napkin holder i designed for someone who wanted extra weight on the bottom. I just made a cavity to put them in that was easily covered.
Under traditional rules that’s not cheating. The basic rules are you needed to use the official pinewood block, nails (axles) and wheels. Anything else could be added or removed (like carving away all but a skeleton for the body) except rubber bands or other similar active power producing devices.
We routinely used .45 caliber lead bullets to add weight to the car up to the maximum (weight = power = speed). They provided maximum weight density for volume and also allowed us to shave off bits if needed to bring the weight down if our scales didn’t match theirs.
I believe the first year he noticeably added weight, and won, so the next year they said no extra weight or you’d be disqualified. Now, I could be remembering things wrong (it was about 30 years ago!), and it was at a church so they kinda made their own rules. I do remember he modified his car in ways he wasn’t supposed to, and it had to do with hiding the extra weight in there.
I have always loved those little hands on projects and competitions. I think they are great for kids…and adults. And I know I’m derailing this thread a little (I hope no one minds)…but one of my favourites where I grew up was the bathtub races! If you don’t know about it and want to, google Vancouver Island Bathtub Races. They definitely have gotten a lot fancier over the years, but it’s a great event! I remember people going out in unmodified bathtubs with paddles and sinking. If I’m not mistaken, one year might’ve even been the person who made it the farthest, because no one was able to finish!
Our local council wouldn’t let the individual Cub Scout Packs make up new rules - they put the kids at a disadvantage when they competed at the Council and State levels (Pack winners went on to Council races and those winners went to State races). Our Pack generally did very well because we had a boatload of engineer & aerospace dads helping the kids. We did have a rule about the kid needing to do the bulk of the work so it wasn’t a dad project (we had a separate race category for dads who wanted to pit their engineering skills against each other )
I’ve seen those. The big one here are dragon boat races on the river. That used to (pre-pandemic) attract dozens of competitive teams from virtually every college and major corporation in the area. In addition to the boats, you need to go overboard on the costumes as well.
And this is why everyone must own an old-fashioned Dremel unless you have a pneumatic biscuit cutter.
If using a Dremel use the fiber-reinforced cutter on the quick-release holder.
That’s the way it was when I participated in the late ‘60s.
My father and I drilled holes in the underside and filled them with solder until the car was at the exact maximum weight limit. We also chucked the nails into his drill and used emory cloth to polish them to a mirror finish. A dash of graphite on them reduced friction even further.
All those neo-magnets I bought that I discovered I couldn’t use in my Glowforge! Some of the bigger ones can have a hundred-pound pull but perhaps only fifty if on the wood a quarter inch away from the metal.
But I need to figure for two or three-inch wide holders for Gorilla tape, and masking tape (and the twelve-inch masking tape). The 12" wide can have hooks to hang on a shelf or French hook wall.
Also, hacksaw blades are easy, It would be hard to find anything short of a silicon carbide wheel to cut them but they break decently with a tight bend on a vice of some sort.
We use all sorts of tape colors in the film industry. If you’ve worked long enough, your stuff ends up covered in tape. Here’s a photo of a battery charger I had on set. All it did was charge phones but some of the tape we used on the media ended up on it after they were transferred.
You’ll commonly find them on strings like this, often clipped to someone (I’ve got fluorescent pink!). The thinner ones (spike tape) are used for all sorts of things—marking places, marking your stuff, marking camera settings, marks for VFX, etc. Black gaff is used for absolutely everything. There are so many types of tape used in film, it’s tough to even explain all the uses. These are all cloth tape in this photo, there’s also paper tape, which I kind of prefer, but I don’t generally need.
Here, I used console tape for tracking markers so it wouldn’t leave residue behind on the wall, plus it had maximum contrast. For some reason, the Hertz logo has an underline bit and it wasn’t present at this location so it needed to be added in post. Bonus points if you’ve seen this commercial.
