I spent some time prototyping a new design tonight. I wanted it to look more like the Andon Laterns with through tenons. It has 50 pieces and is completely snap together. I used PG Medium Draftboard for this version. The actual piece will be in Cherry or Walnut and have rice paper behind the screens. It is large enough for a low-wattage light to be inserted. It stands 10.5" high and is 8.5" square.
I have always been a woodworker so for me I like to design things that utilize the same aesthetic as I used in my actual lumber pieces.
I hope you like! I will post the finished piece when I get the wood in to produce it.
Thank You! It’s been rolling around in my head for a couple days. Took about 2 hours to draw the design and fix some things and then bam! Finished piece. I like to have it completely designed in my head before I start drawing. Cuts down on design time. Nothing feels better.
You need to change your name to design ninja, holy moly, that’s amazing. I work on some small design for a long time, and then the laser starts double cutting and I turn into a combination of the Macaulay Culkin scream, and the Van Gogh scream.
I love your work!
Also it’s still Thursday here, which means that you are living in the future and have additional future insights.
Lol. Well it is definitely a lot of staring in the distance. My friends think I am crazy half the time. I love Design Ninja. I will have shirts made!!!
Trust me. There was a lot of cussing when I put it together. I know draftboard is a little thicker than the PG Ply but I found a couple of things that could be changed.
