After reading here about Purebond Maple plywood, I decided to get some to try. We have very wet winters in British Columbia, and by the time I got home it had warped a lot.
It’s cut into Forge size pieces now, and weighted down flat. I will check back after a while and let everyone know how it works out. The good side of the material is very nice; back side less so, but still quite usable. It will be interesting to see how well it cuts.
I use a good bit of the 1/4", but I get them to cut to size for me, then stack it and bind it until I get it home.
I live in South Mississippi where we are rarely below 100% RH, so I can feel your pain. Plus, it’s the wettest winter (if you want to call it a winter) in years.
Open flame inside the house (fireplace, even a hot water heater or stove) is also terrible for electronics that use connections or removable chips.
Most of the time you can just reset the chips into the socket and gain connection with the new skinned leg.
But the connectors eventually require some robust cleaning.
Static is terrible, but I have been told the higher your elevation, the more common ball lightening is. I have only seen it in a workplace environment, and that is wild enough without seeing it in your back yard or living room.
And now, back to your regularly scheduled program…
Welcome Ft St. John! I really want to go and visit S&S Turbine up there. They have an Orenda Iroquois engine up there that escaped the scrapping of the Arrow. It was in England at the time and Robin Sipes has brought it back to Canada. He is rebuilding it!
Nah never been that lucky, just tagged along with a friend of mine he knows them pretty well. My work scheduled has never really lined up with their tests tho. I work around some massive engines from time to time with my trade so i tend to get my fill of loud and awesome as it is hehe.
