OK. This is almost acceptable. Probably would benefit further with a few process changes. I used one of my wife’s drawings that was inkjet printed on glossy photo paper. Used spray contact adhesive to put it on MDF. Sprayed Polyurethane over the photo to protect the print. After the poly dried I put masking material over the photo. (The poly keeps the masking from pulling the ink off the paper when you are peeling it) Placed the photo in the laser face down and cut the puzzle pieces. Obviously I didn’t size the puzzle correctly. Couldn’t see the photo for position and guessed incorrectly. Either way, there is still some edge discoloration but not too bad.
