Thanks for posting. I’m sorry about the trouble here.
I have a fix you can try that should stop the tube from getting caught.
- Using two hands, gently roll the laser arm to the front of the bed
- Look under the right end of the laser arm to locate the wire
- Pull the wire gently towards the back of the unit to shift more of it to the other side
Once you’ve finished, the wire should stay in place. If that doesn’t work or if you encounter any issues just let me know and I’ll let you know what’s next.
