I’ve read comments that seem to indicate that you should be able to reorder operations in the UI. Is that actually the case? I can’t seem to drag and drop the thumbnails, and I can’t see anything obvious.
If each of the operations are done in different colors in your vector file, you can drag and drop to reorder I believe.
If you are having trouble doing this, try a different browser. Also, I had trouble doing the drag on my iPad, so try it on a computer instead, if that’s what you’re using.
As scatterbrains said, different colors in the file are treated as separate operations, with each represented with a separate thumbnail. The ability to arrange the order of the process can be very helpful.
You should be able to drag them up or down on the side bar.
I had trouble with drag to reorder in Safari and success in Chrome and Firefox.
I’m aware of the different colors. Dragging and dropping doesn’t appear to work in Safari. I will try a different browser.
Yeah…Safari is full of bugs so far. It’s known they are there but still “beta”.
Firefox worked for me, where Safari didn’t.
If you’re not using chrome already I don’t know what you are doing with your life.
It would be great if you could post the issue with the browser you’re using to the Problems and Support topic so it gets reported. Thanks!
I have reported the reorder issue in Safari to the support email address.
As long as it’s reported somewhere. No need creating two tickets by using two methods.
