Hey folks! I am trying to work with an artist who does paintings by laying down vinyl lettering, painting over top, and then peeling away the vinyl. She asked if I would be able to cut some vinyl for her, to which I said no, but I am seeking an alternative. It doesn’t have to be the same consistency–it really just needs to be waterproof, it needs to stick in place when she’s working, and it needs to peel away easily.
What kind of paint? Watercolor is going to be different from acrylic…for watercolor you need Friskit film. For acrylic you can probably use something like:
Mylar sheet might work but the ones I have seen have very strong adhesive, which would make removing them hard. Or, you have to do the work of putting your own adhesive on. AND, you have the problem of maintaining registration.
Something like sign vinyl, can can be cut while on a carrier, would be a lot easier to work with.
I have seen references to laser-safe polyester sign material but can’t actually find a product for sale.
Ah. If it’s a one-off then that’s a different story. Other suggestions on masking solutions would likely work. I think the siser laser safe vinyl though is heat transfer and likely not what you want.
Depending on size needs and resistance to moisture, PostIt Tape might also be worth investigating. I have used it for some masking applications with ink.
