So this is more of a feature request, if you use the drawing tools in the GFUI and you add a rectangle, and you rotate it, the scale drag handles no longer function in an obvious fashion. So in Illustrator of you rotate a rectangle the top “vertical” scale handle still works to scale that axis regardless of rotation of the rectangle (which can be somewhat confusing when the shape is rotated more than 180 degrees) but the GFUI doesn’t support this. so if you are trying to scale a rotated rectangle it is very hard to scale it and rotate it (to enclose a rotated text block for instance)
Hi @henryhbk, Thanks so much for the suggestion! I’ll make sure the team gets this.
Happy printing, and let us know if you have any other awesome ideas!
