just blew my machine out with air and go back to it a lil while later and i get the safety interlock alert. How do I fix this??
Which model do you have. Reading through similar posts. there is a button on the back of the Pros. Can you check that to see if it is tripped.
Edit, Sorry. I see it in the title.
Looking at all the recent posts for the listed issue, it ended in replacement. Hopefully that’s not the case here.
There is no interlock on the Plus. Something got messed up (probably disconnected a jumper from blowing air in there), unit will likely need to be repaired as suggested above.
What jumper could it be? I can fix something like that myself
Hi @stanfill96 - I’m going to go ahead and close this topic as it appears we’ve been in contact about details for a repair on this printer via email. Please follow up in that email thread if you have any questions!
