I’m scaling my objects property in Illustrator, from what I can tell. I’m using millimeters in Fusion360, then illustrator, then i bring into glowforge. There seems to be some kind of scaling translation problem between illustrator and glowforge. Everything I import is smaller than what Illustrator says. For example, my cuts to connect pieces together are supposed to be 3mm wide. They are 2.5mm.
I just created an image on Illustrator, Illustrator says its 65mm. Glowforge says its 50 and shows it as 50. ??
I’m so confused. What could be wrong?
