I searched, but couldn’t find… what’s the difference in appearance?
I assume engrave takes longer. Is that just for fills?
Is one come out as a thicker line?
Score is basically a low-powered cut. It will be the laser following a single path, a laser-beam wide.
Raster is a back and forth motion for fills and rasters.
Engrave is always going to take longer.
Yes. The engrave will be the thickness of the line plus about a kerf. A score is basically the width of the laser beam.
The other difference is that currently at corners a score/cut leaves a little extra burn that the engrave doesn’t.
This document from The Matrix has some great descriptions:
Which means you can make it thicker if you defocus the score operation - the beam will be larger by the time it hits the material. It makes for a thicker line than if you leave it focused to the material height.
An engrave can be done on an area that is enclosed within a path, either vector or raster (use a raster to have the most engrave options available ).
A score can be done to an open path, like a straight line for example, or any path that’s not closed.
