OK so we are back at the failing set focus issues again. OK so setting focus is failing 100% of the time again with the most unhelpful error message:
(that is the equivalent of the “does not compute” that Rodney the robot on lost in space used to say). If it’s a network issue tell me, if it’s a camera blurry issue tell me, electrical, whatever…
Anyway, so last time you folks thought it might be wifi. My problem with that is that A) my wifi seems to be working great if I place a laptop on top of my GF I get very fast connectivity (80+mbit symmetric) and B) that doesn’t explain why everything else on my machine works like a champ, So homing, no problem, refresh bed image, no problem, running a job, no problem. So either set focus is particularly wifi sensitive in some way compared to everything else the machine does, or there is something else going on here. I know yesterday there was some network funkiness on the internet so tried again this morning and same result. I’m going to try rebooting the machine to see if that helps?
And BTW: if wifi is this often a problem for you guys, add a diagnostics function under the … menu. Like do a wifi test to the cloud. (not just total pass/fail, but speed and whatever other things cause issues for the machine).
