Hey everyone,
I ordered some 12 x 12" square draftboard from Etsy that is 1/4" thick.
It was my first time cutting thicker draftboard. I used the
proofgrade settings for thick draftboard but it didn’t cut all the way through. Then I tried with two passes that didn’t work either (burned it pretty good on this try).
I tried to compensate by trying to cut a square out of the 1/8" thick 12 x 20 " pieces I had - only to realize that the a vertical line will only cut about 11" across.
I know I need to edit my letters or they are going to fall out all together - so please never mind that part.
Any suggestions for other settings I can try on this thick draftboard?
Thank you.
