erm… they are in the post you replied to?
“Proofgrade draftboard (thick) settings”
I cant even get close to cutting. my 1/4 inch mdf board. I am going crazy trying to figure this out. newbie here.
Might want to mind the dates. This post you’re replying to is 3 years old.
If you need help there’s going to the Glowforge support page to request their help or the #problems-and-support area where we, your fellow customers, might be able to lend a hand or some ideas.
Not all MDF is created equal! If your glowforge is operating normally on proofgrade materials we can assume you’ve got a stubborn batch of MDF.
You may be able to use multiple passes to cut through the material, but that often leaves very charred edge and increases the kerf.
A couple months back, I purchased new 1/4 MDF. I experimented with at least 15 different settings. Nothing worked that was acceptable.
I could take the speed down to 120 but that was way too much char.
Thanks for your comments, I was having trouble cutting 1/4 MDF, not anymore. I used .15 and 3 bypasses.
