Any tips on making this machine connect to wifi? I have tried every trouble shooting scenario I read on support. Nothing has worked…
can you tell us what you have tried?
Try using your phone as a wifi hot-spot. If it connects to that, the issue is with your local wifi. If not, the machine will likely need to be replaced.
Already tried that as well.
Support will check in and probably contact by email to arrange next steps…
Hello @Nick_Smallwood, I see you also emailed us about this and we’ve responded to you there. To avoid duplication, I’m going to close this topic.
