LOL. Thanks!
Amazing! Canāt wait to try! Thank you for sharing!
Thanks! Let me know if you have any issues. Pretty easy design.
This is fantastic! Any tips on where you found the images you used? Having trouble finding a good death star option.
Iāll drop the file on here in just a few!
Hey sorry. I have been running around like a chicken with my head cutoff and I just finished an order of 600 ornaments. I promise to send it to you tomorrow!
I get it! Busy time of year. Glad you are so busy!
Itās my good deed for the year. Iām making the ornaments for my kidsā school. They paid for the materials but Iāve been making them for about 6 days straight. Now I have to focus on my proper orders! Also I have to say thank you so much. Iām making their teachers the let it snow light up and they look amazing!
Absolutely no rush, and thank you for being willing to post them up in the first place!
What material thicknesses did you use?
Medium acrylic and 1/8ā pg wood.
thank you!
So I was finally able to cut this out and Iām not sure exactly went wrong. It seems like the glowforge didnāt scale the cuts properly? I just uploaded the design to the glowforge and moved it over to my wood and specified ācutā, and all of the grooves that are supposed to interlock with the edge of a piece of the wood are not big enough. I didnāt change the scale of anything, does anyone have any advice?
I am sorry you had a problem with the file. I just downloaded the file and everything looks fine. What do you mean by not big enough? Can you show me what you mean?
The slots are all 2.38mm (in Inkscape) but they appear to be correct in the UIā¦
Probably the lovely AI dpi mismatch rearing its head again.
So the slots on the bottom piece that interlock to the side pieces are not wide enough to fit the thickness of the wood into them, so it isnāt able to be assembled. I donāt have a way to upload a picture at the moment, so hopefully that makes sense.
And you are working with 1/8" Material? Here is a pdf of the file. See if that makes a difference.
BoxForCoasters.pdf (45.9 KB)
Yeah. Admittedly itās not PG, but itās 1/8" Baltic Birch. Every measuring device we have on hand puts it right at 1/8". Unfortunately we donāt have any calipers on hand. Weāve requested them but the powers that be havenāt acquired them for us yet.
Iāll give the PDF a try and see if it works any differently.
Try the pdf file. Also, there is a small nodule sticking out on all the slots that will lock into the piece. You do have to pull that back a little to get the pieces to slide.
2.38mm*96/72=3.17mm=0.1249in
Sure sounds like the AI dpi mismatch
