I tried to make a purchase and got a shopping cart error. I tried to check to see if it had actually gone through and the purchase history page also shows an error.
Last time this happened I ended up being charged multiple times. You quickly fixed the problem! But, instead of assuming the order didn’t go through this time, I am assuming it did.
Thanks for letting us know about this. I checked on your order and do see the purchase attempt, but, as you saw, the order did not go through.
Would you mind making a call to your bank to let them know you approve the purchase? Since we’re a new vendor, some banks trigger blocks or holds on the card as a security measure. Usually a call solves the problem.
