Show your UV printed projects!
Very nice! That little crate is adorable, and the coloring on the new one looks great!
Your image of the bed looks tilted to the right. Was it that way from when you set up the machine? Mine is the same but I can’t tell if that’s a new phenomenon maybe pointing to the need to do another calibration run or if it’s normal and I’m just concerned for nothing. It hasn’t seemed to affect anything I’ve printed but I’m not doing serious precision work.
Starting to work on some Christmas ornaments…cut with GF 1/8 ply and printed on Eufymake…it’s textured and the quality is so good.
:man_shrugging: Maybe optical illusion from the diagonal lines at the edges? Nothing caught my eye at the time I was arranging the artwork.
Recounting my exact process:
After the Omni scan, I imported the first square PNG (before masking out the circular content). The image edge lined up square with the edges of the DraftBoard pieces.
When the DraftBoard pieces themselves were placed on the Adhesive Platform, I used a metal straightedge as a parametric spacer so that the material would stay perpendicular.
Now that a suspected tilt is being pointed out, I took the same screengrab image into Affinity, zoomed in, and laid down some yellow rectangles. Their edges seem to line up reasonably parallel to elements in the screengrab.
If this is referring to the white buffer space top and bottom, I re-arranged those rectangles to show no detectable skewing…
Oooo, nice!
That is absolutely beautiful! Old fashioned light posts have always been a favorite for me.
It’s funny because the white background looks even across the screen relative to the top of the black border as well as the bottom of the menu bar. But the yellow rectangle on the top looks skewed with a taller right side. If you made it a rectangle then it can’t be but it does look skewed to me. I wonder if it is an optical illusion as you said. Maybe because of the slash marks on the plate border? It’s driving my OCD nuts :grinning_face_with_smiling_eyes:
Today’s exercise, “Stained Glass”
It’s been one of the top curiosities I had with UV printers. Curiosity for me usually starts by seeing how the sausage is made…
I grabbed one of the free ready-to-go stained glass projects from xTool’s Atomm Creative Space repository in hopes of dissecting it to see what makes it tick and see what’s required.
The particular one I grabbed was two overlayed images, one serving the color panes, and the other represents the “metal” frame.
I grabbed a throwaway piece of acrylic and straight-up just hit the Process button. Still not tired of that pretty color accuracy…
It’s a great simulation of stained glass, but my only nit to pick is that the default setting had it laying down it’s normal white backing just before printing the color layer. In most normal/typical circumstances, it means helping the color stay bright and vivid no matter what opaque material this is laid on. This “issue” is only an obstacle for a print that might get viewed from the back…
I grabbed another acrylic scrap (1” diameter) and changed the setting… no white backing, color resin only for the base image. On the “metal frame” image layer, I specified 3 repeated layers with expectations it’ll build up. Directly laid on white paper, it looks very similar to the first print.
Sat upright, it’s certainly properly translucent.
Viewing it from the backside, it still passes as “stained glass”
Dollhouses can now be suuuuuuper-fancy. Cathedrals built for a model train environment can be a bonafide centerpiece. These findings are begging for a candle-holder box to be made.
Stained glass is a favorite of mine. Enjoyed your write-up!
That is great! Okay, so now I want a UV printer. Still don’t have room (or money) for one, but someday…
I’ve been having fun with the stained glass look, too! Here are some ornaments I cut on the Glowforge from 1/4” acrylic. They are for three family members and the images were generated from photos of each of their houses. Along the sides are uv-dtf stickers listing the address on one side and Christmas 2026 on the other.
Those turned out great! What’s a dtf sticker?
Direct to film. (Not to be confused with direct to fabric, which is also called dtf, but is a different process.) Dtf stickers are made by uv-printing on a film (called “A” film) that has adhesive on both sides. You peel off the protective sheet from the top and print directly on the adhesive. Then you apply a different film (“B” film) using a laminator. The B film picks up both the unprinted adhesive and the printed sticker, which you peel off the A film backing. You can then apply the sticker to any hard, nonporous surface and squeegee it down. The last step is peeling off the B film which also takes the unprinted adhesive, leaving the printed sticker behind on the item. It ends up looking like the item was directly printed. Works great for items that can’t be directly printed like coffee mugs (unless you have a rotary attachment for your printer, which I don’t).
These turned out beautifu @cynd11. I bet the family will be thrilled.
Thanks for educating some of us about direct to film.
Thanks for the great explanation!
They’re gorgeous!!!
This turned out great @cynd11 . And of significant note on those dtf stickers…once you put them down, they are there forever :rofl: . There’s no peeling and repositioning! But I love them. I do have the rotary and that is still my preference.
If you have a vinyl cutter, UV printing on white vinyl makes a quite credible sticker.
Yes, I have a Silhouette, and I get great print and cut results using the registration marks applied in Silhouette Studio and printed on the Omni.
I had originally done the ortho-bro patch for a colleague (chatGPT did the artwork), and on the EufyMake you can make a custom bump-map (or as they call it Height-Map) so whatever parts I want are raised (and by using various gray values you can decide how far, if you set the total height to 1.2mm and put something in 50% gray you get 0.6mm. That got printed on Lonestar Adhesives Leatherette patches:
Here is a bump map
I happened to post it on a veterinary 3D printing website (since it’s 2.5D) and got some people wanting orders. But that made me decide hey I should make versions for different specialties. So now I have an entire line of fake-vintage medical specialty patches (there are male and female versions of every patch)
(camera struggled a bit with that one, it’s not grainy in real life.)
