What setting should I use to engrave onto a watch band?
I just did some using 600/60/vary power/340 dpi.
I will have to try it! Thank you so much!
Also FWIW filled vector designs will engrave better on the silicone than rasters. I’ve been experimenting with both.
Using the search function here in the forum will be very helpful to you. I did a search for you and this popped up: Silicone watch band setting
Is it just horrible that I have NO idea what you are talking about. I just got my machine today!
Thank you!
Oh, then by all means go do the tutorials before you try to jump into anything else!
I second what @geek2nurse said. It will really help if you learn to walk before you run
