Okay, I put up some slat wall some time ago and it was not long until I realized that this was one of the smartest things I had done in the lair. The problem was that I didn’t order enough hooks and then I realized that I was designing and making other things for the wall, why not simple hooks!
I designed the short ones first and then the long ones, both are very useful to me.
If you need other things to hang from your slat wall you can use the hook portion as a starting point for your project.
If I am cutting these from 1/8" scrap I usually laminate two or three together, 1/4" is fine as is.
You crack me up. I’m a pig and try to have way too much going in one little room so constantly trying to organize is my only defense! If I live to retirement I am going to spend 25% of all my time organizing until it is actually organized!
Don’t do it! Every time I organize I can’t find anything! My solution is to throw piles of stuff into the air once in awhile to find stuff I thought I’d lost.
Very important note* If you decide to try organize using the Andrea Method, it only works if you shout “Yippee!!!” three times and giggle like you’ve gone mad. It’s fun but also keeps anyone out of your disorganized organized mess. Good luck.
Seriously though, thank you so much for sharing your idea. I do 15 different crafts, all with their own bits and pieces and tools. Your method combined with mine will make for fun crafting.
I tend to use the archaeological method try and remember where it was and dig down till you get to stuff that you know came from an earlier time. the tricky part is putting ut back in the right order.
