I just replaced my air assist fan to cut down on flame. Cleaned all the fans while I was at it. Now that everything is clean, my machine is leaking smoke on all sides. Like the fans aren’t pulling smoke out?
All are facing the correct direction. Any thoughts? It wasn’t doing this prior
If you are venting outside and do not have an inline fan, make sure that the air filter is toggled off in the interface.
If you are using the filter rather than venting to the outside, your filter could be full.
