Just good news in my opinion, more Z depth give us a lot of new materials to try.
Itās also enough to make some of the tricks like laser slumping of acrylic worthwhile. Simple boxes and trays.
No from a general approach but yes for different operation/material combinations. I do most engraves at 500mm/s & 35-50% power depending on material. For cuts Iām almost always at 95% power with speeds varying from 10mm/s to 50mm/s again material dependent.
I have basic settings within those ranges for each material I tend to use. I tweak it based on the results of a test run.
So in theory in a future cloud update with proofgrade material as the laser head slows through the braking zone you could increase power to compensate and make it useable if slower to work in?
Yes you can (should) adjust the power/speed on the fly. Thatās one of the cool things GFs can do.
Thatās not quite what I was angling for there, but It was still a great read.
@dan This is exactly the reason to have hard marks on the bed of the laser. Having to no reposition based on software curtains sounds really tedious and kindof goofy. Increased internal space is great, but critical alignment is even harder when the cut area doesnāt match the bed area. PLEASE consider placing hard marks/stops somewhere in the unit for physical guides. Even a simple boundry mark on the side rail would be a good start.
It would be great to read it in an email below the words āYour tracking number isā¦ā
Exactly.
I apologize. That should say it cuts about 20% faster - Iāve fixed it for future readers. Cutting operations are limited by power, which is different between models; engraving operations are limited by motor speed, which is the same.
Iāll take that bet! We think up new things all the time!
When cutting, itās usually best to operate at full power, then adjust the speed. If your speed is at max, then you can dial back the power.
Right, although when you slow down you actually need to decrease power since youāre exposing each area to more laser energy when you slow down.
Unfortunately that wonāt be a part of the product, but fortunately itās an easy thing for you to put your own marks on the bed if you want to - but itās probably best to continue that conversation in the thread about the topic and not here, though.
I also accelerate through curves - one of my lasers allows me to have separate speeds for operating, travel and curve transit. That way I can have very fast travel between positions where the laser is not firing, different speeds for cutting & engraving (by line color in the software) and a setting for cutting in a curve to make up for the delivered power difference in curve transits vs straight lines.
BTW, can we adjust an āoverlapā parameter for cuts? One that control how far a cut will overlap its starting position on a closed object? I use that to help smooth out the cuts - it prevents a little nib of material that sometimes results if the laser turns on & off at the same place but itās almost but not quite to the start. Thicker materials get a larger overlap and thinner ones less (since thicker material doesnāt get the full impact of the laser at the precise point it starts).
Thanks for the update, @dan!
Losing that half inch depth of working space is unfortunate, but I am glad to hear of the 2" height and additional .4" of length.
Would you consider a 24" wide bed in the future? Many acrylic sheets ship at this width sonce theyāre manufactured at 48" x 48", and it would be nice to not have to cut roughly 4" off before I can work with them.
Either way, I am glad to hear of the progress! Thanks for the updates!
While I imagine people will play with manual settings on occasion, I have a suspicion that most people will select a āClose enoughā proofgrade option and just use that for whatever material (even non-proofgrade) they plan to work with.
I am not old hat at laser use. But my experience is that I have a standard power, and vary the speed (that standard power being 100%, because my stuff doesnāt need to look good, just get done fast). I rarely go with lower power, but I understand that some materials have a nicer finish at lower powers.
Business card holder should just fit.
The honeycomb will be essentially your cut area. There is a small gap between honeycomb and side walls in the front, and a large section of honeycomb tray (not actual honeycomb, but part of the same unit) and then an open void behind the cut area until you reach the other wall.
Good point!!! That will be an interesting test, to see if the focus can compensate for a cylindrical surface so you may only have to rotate an object 3 or 4 times (90 to 120 degrees) to cover the 360 degrees surface.
We do this automatically - varying the laserās speed to accommodate turns.
We handle this automatically for you too.
Weāll consider anything for the future! But right now weāre 100% focused on getting this product done right for you.
Woohoo! Love that. One more setting (actually two) I wonāt need to worry about. (The tweakers in the crowd may now be moaning the loss of control of a setting variable they like to mess with though )
Okay reading the prerelease letter this is still in work but once it is working Iād think 8 or more turns for a cylinder so that the angle is never too far away from 90Ā°
I would love a 24" version. Could do custom engraving for truck mudflaps and could cut the larger rear windows (clear acrylic stands up to rocks pretty well) of truck cabs on demand.
If you want more or less overlap, you can still do that by just creating the vector with more or less overlap. Crude example:
Thanks. Iām good with the machine taking care of it (as long as it works). Iām assuming youāre figuring out how much to over travel if any based on your testing. I appreciate not having to worry about one more setting - part of the āmake it easierā mantra. But if not, Iām good with the overdraw the line - I have to do that with one of my lasers but not the other. I do usually have a target machine in mind when Iām doing a design so itās not hard to fit into the workflow. But the CAD software on the one that I have to specify the over travel on remembers the last setting so I sometimes forget to change it as Iām changing the other parameters on the cut color. Nice to have the machine take care of that if it can.
$0.02: Iāve never had to do anything other than relax and enjoy the default setting.
